Unfortunately this is no the problem. It seems that it messes up the top layer before starting printing the top graphics. I don't know if I'm telling it correct. I tried to print it with different layer height and line width but it didn't came up well.
DivingDuck 104
It is maybe a good idea to attache the project file here so that one is able to take a closer look.
DivingDuck 104
One possible explanation is the layer height is not matching with your model.
You are able to verify this:
Check how much layers you have and then look at your layer height settings, make the math and compare this with the real height of your model. Don't forget your first layer height - it is usually different to the normal layer height.
(Count of layers-1)*layer height + initial layer height
