3d model on cura wont print with proper temp settings.
johnboyman
Posted · 3d model on cura wont print with proper temp settings.
Hello. I have a mingda d2 printer and I am using cura 4.8. My mingda d2 has a default temp for the nozzle at 180 I want to keep it that way but every time I go to print it will reset the temp to 200. So I customized my settings I attached an image of what my settings look like. Hope someone knows whats going on.
    The print temperature is in the material profile, so take a look there and change the temp you need for the material you use.
    You cannot modify the generic profile that come with Cura, but just click on Duplicate and then you should be able to change the temperature.
    Untitled5656.thumb.png.89128ef11b3342275a1a2148b9382193.png.7e53477711ec9ea27f53b589791ba86e.png
    Thanks that totally worked. By the way if anyone else does this click activate I am pretty sure It did not set it right away.
