GregValiant 1,489
That's a big file. Can you scale the model down in Cura?
As a check - if you throw out all the supports and infill and keep the settings as simple as possible will it finish slicing?
It's maybe also a good idea to check Cura's log files whether there was an error or warning during processing the model.
Framar 39
Never ran any file as big as yours. If you have the CAD file you can try different saving or exporting settings that would reduce the file size (by using a more coarse STL setting).
