gr5, I don't know if you're a wizzard, but you were right...I checked the wires on the head and one of thethermocouple wires was loose (I guess all the moving it back and forth loosened it a bit). The calibration process was able to proceed now without any cancelation but the next problem occured...when the head moved from the front left corner to the back left corner it ran smoothly. But when it wanted to go from back left to back right it got stuck after 4 cm, stopped, moved a little bit and stopped again so in the end it stopped in the middle of the bed surface so instead of a square it started to make a rectangle line out of PLA. It wasn't even a line because it got stuck on the X axis.
I guess the belts are to tight?
Miha
gr5 2,192
Do you have an Ulticontroller? If so look for "mintemp" or "maxtemp" error on the UC. If not, I'm not sure how this error is shown.
It's okay to shove the head around when the servos have no power. Try moving the head more towards the middle. I'm guessing there is a loose wire somewhere connecting to the head. I know if you lose connection to the thermocouple you get one of the above errors and everything shuts down until you power cycle. So I am thinking it is that cable. Consider using the alternate cable (for if you have two extruders). It may be that your primary cable has a bad connection or that you didn't plug it all the way in.
