Ultimater 3 - Y axis motion is choppy. Need help fixing.
Posted
· Ultimater 3 - Y axis motion is choppy. Need help fixing.
you seem to be on the right way.
When I read you changed the print head revovering a head flood, I remembered an issue I had when reseating the print head cable some time ago (ic20-error). After retighening the four long print head screws, the movement on Y-direction was also choppy. SLIGHTLY loosen the four long screws (just releasing torque a bit) solved it for me, so I suppose some interference with the linear bearing inside the print head.
Maybe it helps for you.
Regards
Enigma_M4 120
Regards
