Help please
Trickflow
Have you rechecked the level of the print bed? It looks like the filament as not been pushed down to the print bed and as then lifted up.
Sometimes with printers without auto level systems you can knock the print bed level out when removing a print, so that would be a good place to start, but i see it looks like you have a leveling system on your ender looking at the background.
    Removing and placing the flexible magnetic mat doesn't change the bed-leveling (I only had to level the bed 3 times in the past 18 months)...
    It looks like there is some left residue from previous prints, did you clean the printbed? The flexible magnetic bed can best be cleaned with isopropynol alcohol, max. 70%... Without cleaning the material will not stick to the printbed that good...
    What material are you printing? at what temperatures (nozzle and bed)?
        • 1 reply
