I used the default profile, just trying to test the printer out, and left everything at the default settings in Cura.
Oh, OK I see, default, but 0.2mm which looks like fast, I get it now... I didn't notice the custom options.
Edited by AppNinjaI used the default profile, just trying to test the printer out, and left everything at the default settings in Cura.
Edited by AppNinjaThe layer height is not the problem I think but there are more default profiles, so try the "Visual" one which should give better results.
Smithy 1,145
Printing slow solves most issues, so select carefully the profile in Cura, a fast or draft profile is often not the best choice.
Which profile did you use?
