The 13.12-test version indeed allows tighter packing, but it does so by sort of putting an elastic band around the 3D model. This is an optimization, if you want tighter then that you'll have to do it in a proper 3D package. (Or disable the "pushFree" function in Util/ObjectScene.py)
Object-level settings are actually supported by the slicer on "one at a time" object printing, but not in the GUI.
Dim3nsioneer 558
Wishlist for Christmas? :smile:
Which Cura version are you actually referring to? I have the impression Cura 13.12-test allows for very small distances between objects (as long as the gantry height is set to zero).
EDIT: Ok, after having tried it again with Cura 13.12-test I have to agree: the manual placement still is delicate...
