kmanstudios 1,073
Never mind......@jman15x is correct. The colours played with my eyes a bit at first, but yeah, you just have a stair stepping issue as described above.
Edited by kmanstudiosNever mind......@jman15x is correct. The colours played with my eyes a bit at first, but yeah, you just have a stair stepping issue as described above.
Jman15x 0
Unfortunate this is somewhat unavoidable with FDM 3d printers. Because they do not truly print in all 3 directions simultaneously but rather stacks layers of extruded filament in a 2d plane, object orientation is everything. So you could try rotating it 90 degrees to lay it flat but then you use a lot more support, although the print should be stronger in that orientation. The easiest fix here is to reduce you layer height as much as possible and then just do a little bit of post processing. You could also try enabling ironing in cura but in my experience this makes very little if any difference.
