I don't know but you can't print it that way anyway - it will come out horrible with so little support.
Rotate the part 90 degrees so the large flat area is flat on the bed. There's a rotate tool on the left side of cura if you click on the part to rotate.
Then change "support placement" to "everywhere".
"support overhang angle" to 80
"support horizontal expansion" to 2 (so the support reaches the build plate - otherwise it might slip off the PLA and be useless)
gr5 1,506
If you do "file" "save" in cura it creates a project file that has all your settings, your printer settings (machine settings), your STL and how you positioned the STL. So that's more helpful than just the STL.
Try playing with "support horizontal expansion" (make smaller). Also "minimum support x/y distance" (make bigger). If that doesn't work then post the project file please and I'll look more closely.
sanderronde 0
I've tried playing with those settings (setting horizontal expansion to or a low value and x/y to 0, 0.2, 1, 5) but it doesn't really seem to change much regarding the dots. I've attached the project file so you can take a look.
cura_project.3mf
