tinkergnome 839
It's a PWM output between 0-24V - depending on the "Brightness" setting.
The led strips are for 24V (at max. brightness).
tinkergnome 839
As far as i remember: the leds are 3 strips with short (soldered) connector cables in the corners. All held in place with some (self-) adhesive on the front panel.
The whole strand came out in one piece on my printer. It's a while since i removed the (broken) strips, but i definitely did not disassembled any panels, that's for sure... 🙂 I just loosened the adhesive and pulled the strip out.
Do you have any pictures?
This picture is borrowed from the assembly manual:
https://github.com/Ultimaker/Ultimaker2/blob/master/um2 assembly manual V1.1 _english.pdf
luisito 12
ok. I have pulled up all the leds. I can see 8V at the wires coming in from from the controller board. is that correct?
I have tested the failing led strips and they light up at 15V or so, but not at 8V.
