Hi, thanx much for the help, but this is not my problem (I should have explained better !). The walls do join, but the ends of the walls do not. I attach a new picture that shows the problem better.
Actually (after posting) I now have the hypothesis that the pressure in the nozzle may not be enough and that there is a short lapse before the printer starts extruding after a jump.
gr5 2,206
Cura has a bit of trouble on thin walls like that that are slightly wider than line widthX2. I assume your line width is 0.7 and so if those internal duplo walls are 1.5mm then there is a .1mm gap. There is a new alpha version of Cura that supposedly does better with this sort of thing here - called arachne:
https://github.com/Ultimaker/Cura/tags
It has lots of buts but might do better. But a better solution is to use this tried and tested version of Cura from one of our community members which does MUCH better on thin walls like this. I use his versions of cura much more often than the Ultimaker version. It's quite safe. I met the guy in person:
https://github.com/smartavionics/Cura/releases
