Disabling the 'remove print from build plate' message after print
SIGMASIX
Posted · Disabling the 'remove print from build plate' message after print
Hello, I'm batch printing part and I would like to know if there was a way, using Gcode to get rid of the 'remove print from build plate' message appearing after each print, since my print are automatically removed with the print head.
BTW I'm using the bulldozer plugin:
    • 1 month later...
    As far as we know, there is no way to do this with gcode.
    When you use this method/plugin, then you usually don't run into the problem with the message, because you don't repeat a single print job (gcode) several times. In fact it is one big gcode with your initial gcode duplicated and with the removal move between each parts.
