GregValiant 1,324
Right click on the build plate and select all models. Then on the left toolbar select the top tool (the movement tool) and make the "Z" 0. She should drop to the build plate.
- 1
it worked ! Thank you Greg!!!
GregValiant 1,324
So is she a stewardess? Cuz she was kinda floating around in the air up there.
I tipped the head forward about 20°. It isn't flat on the build plate like that and requires additional support. I thought the finish might be better though.
GregValiant 1,324
I used 4.8 and
itshe looks to have sliced correctly. Where did you find a flat area?BTW it looks better with adaptive layers on. This is with adaptive turned off.)
