Posted · Constantly getting extruder mismatch errors - even when not using support.
Hello,
Is there ANY way to disable to the comparison of the extruder heads?
Virtually every print, I get this error. Run it again and it is fine.
Tired of re-calibrating over and over.
Tim
    Hi Tim,
    thank you for your message. Is this for an Ultimaker S5 or a different printer?
    What error do you get? ER38? If so, have you followed these instructions? If you get it frequently with the same print cores you may want to check if there is no debris attached to the nozzles and if your fan brackets still close properly. Good luck!
