It seems to be related to the XY plane position of the model. The first time I tried I had the origin on the printer at front left side. When I imported the model it was placed in the middle of xy pland in CURA software. The model xyz coordinates was zero. Then it started to print outside glass plate... At printer origin.
So I thought that I had to have the printer origin at centre. But then this error message show up.
So some basic questions:
1. Is printer origin the same as model xyz = 0,0,0?
3. In other words, how is printer xyz origin related to model xyz coordinates?
Regards
Hans
SandervG 1,521
Hi, are there any hidden planes on this STL or something that might make it larger? What dimensions does Cura tell you this model is? Do you have any settings enabled like a lot of brim that might make it too large? Do you get a similar warning with other models too?
