Thanks... But it will not slice if I change the nozzle while the software is running. It did slice by setting the nozzle to two then closing and re-opening the program. When the code was run on the BIBO, it seemed OK heating nozzle two, but never would extrude any filament during the movement of the nozzle head. I know the nozzle is working. Have not looked into the gcode to see if I could see what it was or wasn't doing. Thanks for the help... :_)
Enigma_M4 47
if a model is loaded into Cura, it's automatically assigned to extruder 1 by default.
If you want to print it with extruder 2, you have to mark it and select extruder 2 on the left sided menu (lowest icon).
Regards
