Thanks for the reply!
This sounds like a great option, but I'm not able to run the "good" Cura - it crashes on startup. I don't know if it's because it's too old to run on my updated version of macOS, or if the changes made by Monoprice just broke it...
Are project files platform independent? I.e., if I can get the Monoprice version of Cura to work on an older Windows machine can I transfer the save over to my Mac?
gr5 1,506
Startup the older "good" cura. Slice a model with the right settings. Then do menu "File" "Save...". This creates a project file with your machine (printer) settings, your profile settings, and your overrides to the profile. It also saves your model(s) and orientations and other things.
Then exit cura, open the newer cura and open that project file. It should have everything perfect with the machine setup. It will even add the machine to your list of machines available.
I don't use profiles. I use project files. Whenever I go to slice something I think "what did I slice that was similar - oh yeah - that nylon lens holder" I then start with the project file for that similar item, discard the models and drop in the new model. Also of course whenever I save a gcode file I also save the project. It's just a reflex now - I don't think about it.
