I hope to test the settings to morrow sorry for the delay!
Today I finally tested the simplify 3d settings.
The simplfy 3 settings gave more stringing then the default ender 5 profile so my advice is setup the default ender 5 profile edit the bed size and copy the default start an begin end code from the crealty slicer.
- 2 weeks later...
- 2 weeks later...
Are you referring to the Startup and End Script on the SCRIPTs tab?
As far as information on the Gcode page, the size is correct listed 250x250x400.
Michael
- 2 months later...
On 1/17/2021 at 2:56 PM, jan141282 said:this morning I have tested whit the ender 5 profile and this was match better.
the only thing I have changed form the default settings is the begin en end g-code and the machine dimensions.
Could you please share the changes you made to the g codes ?
- 4 weeks later...
On 1/10/2021 at 3:13 AM, jan141282 said:
Hello Everybody!
My brother in law has made a Crealty ender printer 6 profile for Mac and Windows.
We have done some test prints and it looks promising.
Please give us comments if you encounter any problems. otherwise have fun printing whit this profile!!
Trying to install on macOS Big Sur and Cura 4.9.1
Following steps in your readme, all other printers, filament and everything is deleted.
Then when restarting Cura, the only option is to add a new printer, but it hangs and does nothing.
I think by now the profile is outdated!
is there a profile now up to date so I can download that is just got my ender 6 and want a good profile for my Cura slicer
GregValiant 956
There isn't a profile for the Ender 6 yet. Creality might have submitted one and it may make it into the next release of Cura.
When you add a printer, I think the Ender 5 is pretty close. I would install an Ender 5 (you can name the printer whatever you want) and change the build plate size in the Machine Settings within Cura. If you have a heated build volume you need to check the box for that as well. That should get you started.
- 1 month later...
I did not understand how to put the file into cure
spanishcop 1
Sounds great, looking forward to seeing how it does.
So as I mentioned, I've been working on a little project for my Ender 6. LEDS and Camera for remote viewing by Cell when I'm not home. A lot of people really liked what I did with my old ROBO R2 lighting system and the CR10. So here is the Ender 6 take......
I took a pictures to show my Ender 6 lighting.
Mike
