To get good adhesion, I put a thin layer of gluestick on the bed, and then take a wet cloth and spread it around the bed until all the glue has dissolved into the water. Then let it dry as the bed heats up. I print PLA with a bed temp of 60º.
Rather than using Cura's mass support for this print, why not look at Meshmixer, and add some custom supports to the print. It's a lot more versatile, and far easier to remove:
lennart-bruggink 3
I found this in an older post:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
Do you think my problem could be a heating problem? I can relate to the cruling upwards of the print.
Howeeevar: my fan is always on at 100%. Sometimes I do this at less than the first five layers.
