Hi @tinkergnome
Thank you for your response!
On 1/16/2021 at 8:26 PM, tinkergnome said:It should not be possible to set a temperature in Cura if the GCode-flavor is set to "Ultimaker 2". Which Cura version are you using?
I checked, am most definitely using the Ultimaker GCode at this moment. The Cura version is 4.8.0
I should have been more clear, I can stipulate the printing temperature when setting up the material in the "Manage Materials" sections. See attached.
On 1/16/2021 at 8:26 PM, tinkergnome said:40C is indeed the firmware default for PLA and 0.8 and 1mm nozzles. Source:
I will look into this, I have 0.4mm installed and would like to reduce temperature to ±205C for PLA I am using as apposed to manually "Tuning" it with every print.
Thanks again.
Friedl.
tinkergnome 929
If you set it to "Marlin" (the first entry of the list) the hidden settings for temperatures and retractions become visible.
BTW: The printer presents a warning if you start such gcode files. That means that the material settings on the printer are not used for this print. Since this is your intention - choose "continue".
240C is indeed the firmware default for PLA and 0.8 and 1mm nozzles. Source:
https://github.com/Ultimaker/UM2.1-Firmware/blob/UM2.1_JarJar/Marlin/UltiLCD2_menu_material.cpp#L1136
This can be customized in the printers material settings.
