Hi, thanks for the answer
I'm worried about the screws I'm suppose to use with this print,
I'm pretty sure they'll be loose.
but what I'm a little surprised about is that the slicer won't make the hole rounder even with 0.1 or 0.05 layer height
gr5 2,210
I think this is round as is possible given that the hole is sliced into layers. If you ignore that flat top and bottom it looks very round to me.
Regarding "printing oval" - it's probably the top of the hole that is sunken a bit downwards. This overhang is almost horizontal here and that's difficult to print.
Do you care about the "look"? Or do you care about the functionality (is there something that doesn't quite fit).
One solution is this (skip to part about horizontal holes):
https://support.3dverkstan.se/article/38-designing-for-3d-printing
