From first looks it seems to me just looking at the end product that in your CURA settings the S5 has higher height of layers. Have you checked the CURA settings? - to see if they are the same. S3 looks fine and S5 looks draft quality.
Posted
· Utimaker S5 vs Ultimaker 3 Extended Print Quality
I also recommend to use the Intent Profiles with the S5, they are optimized for the printer. If you want to have a perfect surface finish I would use the Visual profile.
zakeen 3
Edited by zakeenLink to post
