I cannot see that there is any "direct" connection between the electronics and the overflow issue.
However, if the lift mechanism in the left slot upper part got a kind of "new" offset there might be an issue, or if it is a permanent offset fixture between the slot guides. (Too much difference in height between the nozzles.)
What kind of error does the printer give?
When the lift switch fail occur, can you see that the switching fail and how?
I.E. Switching from left to right, or the other way around?
Thanks
Torgeir
Torgeir 248
Hi @Jerome68,
Welcome in here.
Thanks
Torgeir
