Thank you for your help, you appear to be right, reading the link you sent I can see my model is in the dark area of the bed. I have encountered this before using Prusa Slicer and simply increased the bed size in the machine settings. I have done this in Cura but now I can see that the print area does not increase, only the outer area around the print area.
My print bed is 220 x 220 and my model is 220.2 x 219 so I will have to go back to the drawing board and try to reduce the size a little.
Once again, thank very much. Graham.
1
gr5 2,210
Can you show a screen shot? How close is the model to the edge? I'm going to assume it's just barely small enough to fit? Is that correct?
If my assumption is correct try these things from another topic:
set "travel avoid distance" to zero.
disable brim and skirt both!
details here:
https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
If I'm completely wrong in my assumption then zoom way out - there might be some extra mesh portions in the STL that are not "part" of the model in your mind but are in the STL file - there could be something far far away from most of the model. Am I making sense? Imagine a model of a 2 one inch cubes separated by 20 inches. You see one of them but don't realize there's a second thing way over off the screen.
