Ultimaker 2 failed extruder in less than a week
uma
Posted · Ultimaker 2 failed extruder in less than a week
Hi there,
I got an Ultimaker 2 recently.
I have been using the machine for the last one week. I made some successful prints using PLA blue. What is unfortunate is that the material feeder has lost its tension. I tried adjusting the screw in the extruder mechanism but to no avail. As it stands, even though the gap between the stepper knurl and the white head is small inserting material is no longer tough. The day i got the printer it was very difficult to push the mateiral in. Now, its very easy. The material reaches upto the extruder but not past the extruder head. I tried removing the bowden and pushed filament by hand which worked. This squarely leaves to failure of extruder mecahnism.
Now, If i try to print, the small nut on the stepper connecting the knurl becomes loose and the stepper just stops. For now, the machine is down and i have some important prints to do.
Overall the machine looks good from the outside but i am deeply concerned about the build quality. I waited for UM2 more than a month. I am not sure whether its worth the wait.
1) Have any of you faced a similar problem
2) Is there an assembly instruction for UM2 feeder. I am still not sure how the adjustment screw inside the assembly works. It just keeps on rotating as i try to tighten it.
Your help is much appreciated.
Uma
    did you open up the casing of the extruder and check it out ?
    one little thing i learned is... when you open the casing make sure you take off the protective metal housing infront of the motor inside the printer.. other wise when you take the screws out of the housing... the motor can actually fall out.. oppps... just as a tip !
    Ian :-)
    I suspect you have to remove the cover of the extruder because you need to push that knurled part further in before tightening the set screw that holds it. Make sure that set screw is very tight.
    There are 4 screws holding the cover on - take all 4 out but beware the motor will fall so hold the stepper as you do this. This is a pretty easy fix so don't be scared.
    Thanks for the pictures. I had already opened the casing of the extruder (after removing the white shield etc). From what i see compared to the pictures (link in illuminarti's reply) the metal screw (used for tensioning may be?) is not standing as proud as shown in the pictures. Also, i tried tightening the small screw which attaches the knurl as much as i can but the story repeats. Not sure where i went wrong. Should the tensioner screw stand proud or driven in?
    Uma
    Hi Uma,
    Could you send a picture of your current situation/set up?
    What does your feeder mechanism look like?
    It would be much easier to give some concrete tips on how to put it back together properly :)
    Thank you for your time!
    Hi SandervG
    Here you go! I am attaching the pictures. As i suspect either the screw or black casing seems to be the issue. Please advice. Is the small screw a standard part number? Can i get it in local hardware store?
    I look forward to resolve this.
    Uma
    PHOTO   EXTRUDER MECHANISM
    EXTRUDER   SCREW
    EXTRUDER   SCREW TIGHT
    The screw you point to - I think you want to loosen it a great deal, then slide the knurled part inward, then tighten the tiny screw again. I have not take this apart yet myself so I may be ignorant.
    gr5, By adding a lot more tension to the white roller i think i risk knurled part to get loose even quicker. Because, the tiny screw comes loose when the white roller is not at high tension. Does anybody know where i can get the tiny screw?
    Happy new year folks!
    Uma
    This does not make sense. The tiny screw needs to be very very tight. I think you just aren't tightening it enough. Tighten it so much that you are afraid of breaking the screwdriver/hexdriver.
    The white roller should be close to the lowest tension - the white square that shows through the left side should be near the top.
    @gr5 you absolutely makes sense. Thats what i thought as well. The white square is at the top and the white roller is close to the lowest tension. But what i suspect is the broken hex head in the tiny screw. The allen key slips right after two turns. Would you mind posting a picture of your extruder gearing mechanism. I just want to know how proud is the tiny screw?
    I guess there is no standard part number fo the screw. I hope the Ultimaker guys come to my rescue.
    Uma
    The grub screws you can get from ebay. M3 x 5mm. You can get 4 for £0.99.
    I just finished modifying my extruder motor, I machined a flat onto the shaft and used blue loctite on the grub screw.
    P1000797
    P1000796
    Try buying steel ones instead of stainless steel...steel bolts (especially 12.9 strength class) can handle so much more than stainless steel bolts... I don't know why um company even uses stainless...they are much more expensive...
    Mine looks like yours. It sticks out quite a bit. Just like yours. Maybe the threads are stripped (ruined).
    Hi Uma,
    Can you still get your screw out?
    I can set you a couple of new set screws if you want!
    Best wishes for 2014!
    Is the problem solved with the teethed bolt sleeve? Or do you also still have difficulties with the tension of the drive mechanism?
    @SandervG
    i have replaced the set screws but the tension in the drive mechanism is still low. I tried loosening the long screw as well. Dont know where the problem is. I need to resolve this asap. the machine has been down for almost a week.
    Thanks for your support
    Uma
    I think you should show a video of the problem.
    1) Does the knurled piece spin or is it tight with the motor now?
    2) I see no problem with the other screw - it should be able to control tension. Can you demonstrate the problem as everything sounds great except that your knurled piece seemed to be slipping.
    It seems like the problem is solved with a new screw. I am yet to print a large model to see whether the problem repeats.
    Thanks for your inputs. I will update by EOD.
    Uma
    let us know what happens !
    Ian :-)
    I had my Ultimaker 2 for 2 days and printed the ultimaker robot and 3 little usb cable clips for iphone 5 my power supply is making these weird noises. The motor to extrude the filament just quit today these prints are only 30 minutes..
    Here are the links to show you my problems of on day 2 of owning a Ultimaker 2
    http://www.youtube.com/watch?v=xC_sPIFjKII
    http://www.youtube.com/watch?v=6jPgqAf11ec
    Vinay, the problem you are facing is similar to mine. Did you try tightening the small hex screw in the knurled rotor? It looks like it is sticking proud and knurled object is also projecting more than it should.
    After I tightened the hex screw it started working. I figured that the gap between the nozzle and the heated bed is an important parameter. Mine was less than 1 mm which made the extruder make some ticking noise. What i infer ithat as we build parts the pressure in the nozzle builds up considerably. This cause considerable pressure in the feeder mechanism. I may be wrong but after aligning the heated bed I did not see the problem again.
    Thanks
    Uma
    @vinay - everything sounds mostly normal except the extruder is skipping back during your print.
    So first of all the sounds in the first video sound fine. I don't see the stepper turning. Is it? Obviously it is supposed to turn. But the sounds it makes are normal.
    In the second video it looks like you are printing fine. I can hear occasional retraction, but I also hear when the extruder motor skips backwards. You should look at it - you should have videoed the stepper then but I'm pretty sure I know what is happening. What speed/temp/layer height are you printing at? You should either print thinner layers, print slower, or higher temp because your extruder stepper is slipping occasionally. The extruder stepper is designed to skip backwards if the pressure gets too high in the print head. This is usually caused by printing too much volume of PLA too fast.
    Uma, I took it apart to see how it works and yes it was the hex screw it was loose and it slid off, thanks Uma! it works now Just need to find out the noise coming from my power supply.. Does your machine LED light slightly flicker?
    @Vinay No the LED doesnt flicker normally but when the machine accelerates it sometimes flickers
    Thank you Uma and gr5! :smile:
    Yes it only flickers when it prints so this is normal, good just wanted to make sure..
    I can't remember what speed I was printing at in the video..
    I don't mind printing slow I enjoy the high detail now I just print at
    speed 30%
    room temp 13c or 55f depends how cold the room is..
    print head 190c- 201c
    heated bed 75c-78c
    layer height 0.1
    The noise from the Z motor is normal too? skip to 0:46 and you will hear the z motor
        • 31 replies
        • 25 replies
