22 minutes ago, Torgeir said:Hi @paoletto,
after looking and listening to the noise I'll think this noise come from feeder no 1(if you're printing with this core).
This sounds like tooth gear working kind of hard and the clicking sound might be missed steps..
Often the root of such a fail is found in the extruder head.
If the forward fan stop working (the fan inside the nozzle core door), -not cooling the upper part of the cores.
This will increase the force required to feed the filament (due to friction increasing), and may soon stop feeding filament to the heat core.
Sure, a print core blockage may also cause such a problem, but first check this fan..
Good luck
Thanks
Torgeir
Thank you Torgeir for your input, i will look into this.
However, i would like to point out that this noise is apparent mostly in just one part of the front-to-back swipe, and it doesn't happen below or above. If i pay attention, it also happens around the same y position when the head is printing gyroid infill so wiggling left and right..
Torgeir 166
Hi @paoletto,
Good luck
Thanks
Torgeir
Missing text.
