Thanks for the help getting started.
Here's a image showing the wall in different colors at the highest magnification I could achieve. It appears to show two shells with a single inner wall. Great that is my goal. However, when you look at the resulting gcode file you will see there are two inner walls. The first inner wall starts at line 516 and extrudes material at an expected rate. The second inner wall starts around line 588 and extrudes almost nothing. The extrusion rate for the second inner wall is only about 0.5% of the first inner wall. Not only does this waste time but it also leads to other problems with PETG which tends to ooze. The two outer walls begin at line 660 and extrude a similar flow to the first inner wall. The higher layers follow the same pattern.
As I stated in my initial post my goal is to print some fittings for my dust collection system. They are all some variant of a hollow cylinder with relatively thin walls. Many of them will be several hundred layers and the extra wall greatly increases the printing time. With PETG it also leads to gaps following the extra layer as some plastic has oozed out of the nozzle so when extrusion resumes there is a gap of missing plastic. There is no gap between the start or end of the other walls so it is not a tuning issue.
I have included the project file along with the gcode file. I have printed this test piece in both PLA and PETG. The PLA print was acceptable but takes about 25% longer to print than necessary. The PETG print was not acceptable due to the gaps formed after the extra blank wall and also takes longer to print. PETG is preferred in this application due its superior layer bonding and overall strength.
How do I configure Cura to eliminate this extra useless wall? As I said I have tried many combinations of wall and extrusion widths, infill patterns, infill percentage and anything else I could find. Every combination that appeared to have 3 solid layers also had a fourth useless layer.
John
TM_5in_ID_duct_test_045-PETG.gcode TM_5in_ID_duct_test_045-PETG.3mf
gr5 2,334
Please look at your part in PREVIEW mode and make sure "color scheme" is set to "line type". Once you do this it will show infill as a separate color. I think you'll find that the "4th wall" is part of the infill. You can get rid of that 4th wall by trying different infill patterns that come with cura.
If I'm wrong then please provide a screen shot that shows the lines in different colors and also please post your project by doing "file" "save..." and post the resulting file here. Note that it will contain your STL file(s) so hopefully that's okay.
