SOLVED Model not appearing in Preview
Thank you for the reply. Here's the project file.
- Also when I attempt to place a raft around the bottom, it seems to talk up the almost the entire build plate.
You have a delta printer! Cool. It slices fine for me as you can see below. I didn't change a thing. Did you click the slice button in the bottom right corner? Did you then switch to PREVIEW mode (I guess you did as stated in the original post).
It says it will need 5.1 meters of filament. Does it show that (just above the slice button)?
Hmm. Maybe try a different computer? I used cura version 4.8. I assume you used the same? Not that it should matter.
Thank you for your help... I made a small step forward. Shut down Cura and started all over. And, the model appeared in Preview.
Onto the next problem... using a new IMAC, it doesn't have a micro SD slot, (I don't have an adapter).
So, connected via USB cable but Cura is not recognizing the printer in Monitor view. Its just blank
Printer is a FLSUN QQ S Pro. Any suggestions? Or is it better just to get an adapter and use the micro SD?
gr5 2,230
Your model is almost certainly not manifold. I didn't look but I've used sketchup and it's all too easy to throw up some walls where one wall just doesn't quite connect. Or I forget to add a "floor" under all the walls. More information here:
https://i.materialise.com/blog/3d-printing-with-sketchup/
