Adding code to print cycle
Carlbosson
Posted · Adding code to print cycle
Sorry I did not see a search to look to see if this has been asked before and I am sure it has. When my print is finished the hot end stays on the print and cools so it is stuck to the print. I would like to add a line of code to the sliced file to tell the printer to home all once the print is complete. I would also like to add a swipe before the print starts. Were do I add this in Cura? Thank in advance for all your help.
    I only looked at the end gcode as that's the critical part.  You put the printer into relative mode but I believe that only affects the E axis (extruder).  Instead use G92 which sets the current position.  Like this:
    G92 Z0 E0    <--- without actually moving any axis - now declare the Z and E axes to be at zero.
    G1 E-1 F1000   <-- retract 1mm
    G1 Z5  <-- move nozzle 5mm farther from print - note this may violate software end stops if your print used the full height
    G1 E-10    <-- retract another 9mm
    G1 X0 Y0 F6000  <-- move nozzle to corner at 100mm/sec
    G28   <-- optional - home all axes - don't do this if it means moving the nozzle to touch the build plate
    By the way, some versions of Marlin seem to ignore that last 1000 or so characters in the gcode file.  This is a bug only in certain versions.  One solution is to add a lot of comments at the end
    Also - did you look at the resulting gcode to see if it correctly added your code at the end?
    Next time please just paste in the code - don't attach a pdf containing a photo of a screenshot.
