Yes, this is the current solution and it works. I have built in the old part yesterday evening and the printer is working without any problems at the moment. I had to cut the Bowden tube a bit - it seemed so that the metal parts inside wore off the tube a bit. I've found some parts inside of the feeder.
Dim3nsioneer 532
If you still have the old white piece that grips the Bowden tube simply tak that one.
