10 minutes ago, Smithy said:When you slice something with a special (new) material profile and save the "gcode" to the USB drive, then a ufp file is written to the stick. ufp files are like gcode files, but they include much more information than just the gcode itself. And that's the way it should work to import new material profiles.
But be aware that the material profiles from the marketplace needs an update from the filament vendor to be compatible with the UM2+C. So I am not sure how much profiles are already updated.
Have tried that already and it still didnt manage to find profiles. So I am thinking maybe that is not the way to do it
Smithy 1,141
