With all the talk of clogs and "boogers", I was looking for the proper procedure to "prime" the print head.
An addition on Priming....
I usually try ( sometimes I forget) to prime every time a print starts.
Specially with repetitive smaller parts you better change the standard start- and endcode.
Might miss something, but how I read the code, I see in the end code a retraction of 6mm.
Startcode says
G1 F200 E3 ;extrude 3mm of feed stock
that's A total of 0,0mm, so every time you start a new print you are 6 mm short of filament. Very Roughly 300mm printinglength? Exact mathematics are for Gr5 or illuminarti
So I try to remember to turn the extruder by hand before the print starts.
IRobertI 516
Priming is simply making sure that chamber inside the nozzle is filled with plastic. This is usually done for you automatically at the start of the print when the machine squirts out a bit of plastic just before starting the print. This is done because when the head is sitting hot for a little while without printing some plastic will drip out, if you were to start printing immediately after this happened (without that extra little squirt at the start) there would be underextrusion until the head has filled back up with plastic.
When you change filament just keep feeding it in until plastic starts coming out in a steady stream and you're done. If you are changing to a different colour you'll have to keep extruding plastic until you have "washed out" the old one from the head. This can be done by manually turning the gear or by printing a small "throw away" print (if you're lazy and don't want to extrude manually
). How long it takes depends. Going from black to white will take longer as black specks/streaks are much more visible on white than say brown on red.
Unless you have an actual clog preventing you from printing/extruding you don't have to do anything special. You can leave the material sitting in the printer indefinitely when it's turned off, it might soak up some moisture after a few weeks but generally that's not something you should worry about. You shouldn't let it sit idle in the machine for long periods if the print head is heated up though, that can cause issues (so don't heat up the print head without starting a print and then walk off to have dinner).
Yes, it can be a bit of a slinky when the spool is full, it gets better as you get rid of a few meters.
If you cut the end of the filament at an angle to make it pointy and sharp and bend it a bit so that it is straight it will be easier.
I hope some of that made some sense, if not, keep asking away.
