Cura - UM3 Extended - Dual Extrusion - Begin each Layer with the same Extruder
KronosMagna
Posted · Cura - UM3 Extended - Dual Extrusion - Begin each Layer with the same Extruder
I am dual printing with an UM3 Extended with Cura. I need Cura to start each Layer with the same extruder(conductive filament on the right one) to get good results. Unfortunatly, Cura starts each layer with the extruder, that was active last in the previous layer. Basically they take turns each layer.
Is there a way to force Cura to begin each layer with Extruder X, even when this means more switches/time?
Thanks for your help!
    Hi
    unfortunately I don't think this is possible. I can remember that someone asked the same question in the past and there was no solution for it.
    • Thanks 1
    9 minutes ago, Smithy said:
    Hi
    Ok, well thank you for quick reply anyways 🙂. Ill try to work around it.
    • 9 months later...
    Hello KronosMagna,
    Did you find a solution to your problem ?
    Because I would like to do exactly the same, start every layer with the same extruder.
    Thank you in advance for your answer
