I actually think i fixed this. The glass plate was about an eighth of an inch off from back to front. Leveling would complete with no errors and print would just end. I manually adjusted the build plate to be a bit more level and it is now printing. The bug is, the machine should be throwing a leveling error but it is not. It just pretends like it is ok and prints nothing at all and cura states print complete.
1
gr5 1,557
Did you look at your print in PREVIEW Mode? Sometimes when you slice a part with, for example, thin walls nothing actually gets printed. When you say "i've printed these items before" did you reslice? Or is this old gcode?
