Good to know. Still trying to work this out. I do believe it is within Cura but not certain. I do have two tabs opened on my browser one for each printer in Octoprint. In cura I can send a print out from either printer profile but no matter what, both prints will show up in the original printer I created on Cura. Each printer in Octoprint has a separate API key. But Cura seems to only accept one as valid. I can drag and drop a print from Cura into each printer in Octoprint. So I know at least that I can print on both printers between both programs. I will play a little more rough with Cura and see if it listens. Thanks for the input.
In the Cura printer settings, you have these 2 printer profiles and for each printer you have a Connect button where you can set the Octorprint instance and the API key. So you have to configure it for each printer. Maybe check that again and don't forget that you have to activate the printer you want to configure before.
Alright, problem solved! I ended up just deleting both printers on Cura and starting over. Honestly, I think the simple problem was (user error) and the fact that I was trying to add the second printer onto Cura when the first printer and Pi was powered up and running, maybe causing some conflict. This time I added ip and api with only one printer and pi on at a time. And it recognized it! I appreciate you for even just giving your input. Help me do the process of elimination.
Thank you!!
1
Glad that it works now and thanks for the feedback!
Happy printing 🙂
Smithy 1,145
Hmm,, hard to say what the problem or reason, but I can say it works without problems normally. I have 3 printers, each with a PI connected to my network and configured normally in Cura. You have to create separate printers in Cura and each printer has its own connection with IP and API key for sending the job to Octoprint. Never had any issues with it.
