Cannot get support to print in my Base
aliengrey10
Posted · Cannot get support to print in my Base
Hi, I am trying to print a small statue which is placed atop a base. I have set infill to various different settings but for some reason the infill will not print in the base, and therefore the statue has no base to stand on. Why can I not get the infill to print in the base??  I have attached the 3mf file and one can see that the pedestal has no top and is printed hollow despite the infill setting. Have I a setting wrong somewhere . I use a creality ender3 pro. Thanks in advance, Al
CE3_pawnV2cura.3mf
    In the Special Modes turn off "Spiralize Outer Contour".  When it's on it only prints the wall.  If you can't see it then next to the settings search box is a drop down for setting visibility.  Select "All".
    2 hours ago, GregValiant said:
    The first thing I do is turn on "All".  I only have a single profile and if settings are hidden I'd forget them and they might be needed for the current model.
    Ayup 🙂 👍
