kmanstudios 1,120
Or you can use the search tool at the top of the settings panel.
Personally, I am all for the show all settings. It is a lot, but, can open a lot of tweaks as you learn.
Sirs, I thank you both this solved my problem. It just shows how easy it is to miss something. Ive been battling all day with blinkers on.😊
The first thing I do is turn on "All". I only have a single profile and if settings are hidden I'd forget them and they might be needed for the current model.
2 hours ago, GregValiant said:The first thing I do is turn on "All". I only have a single profile and if settings are hidden I'd forget them and they might be needed for the current model.
Ayup 🙂 👍
GregValiant 1,351
In the Special Modes turn off "Spiralize Outer Contour". When it's on it only prints the wall. If you can't see it then next to the settings search box is a drop down for setting visibility. Select "All".
