GregValiant 1,330
If it is the very top layer of the model it's pretty easy. If it is an intermediate layer then it's problematic.
For the very top layer you can use a support blocker configured to "Modify settings for overlaps" and as a Cutting Mesh. For settings, select Wall Line Count and Extra Skin Wall Count and set them to 1 and 0 respectively.
With your model - add a support blocker. Scale the X and Y to cover the area you want to change and make it 1mm thick in the Z. Adjust the X Y location over the model and put the Z so it will overlap the top layer.
In the attached file the calibration cube is 25mm tall and the layer height is .2 so I located the support blocker at 24.8 so it only effects the top layer.
Here is a shot of the second to last layer.
And here is the top layer.
1
OnCor 0
I'm wondering about this as well. I'm using some silk filaments that really contrast the outer perimeter against the top/bottom layers because the lines are going in different directions. Being able to change the wall count on the first layer to "1" as dubbeltrubbel suggests would help to make that less obvious. Is this possible in Cura?
