11 minutes ago, Mari said:In the "cura cloud"...???
Thanks! A local solution would be great.
The local solution would be backing up %APPDATA%\cura\4.8 as you indicated.
16 minutes ago, ahoeben said:The local solution would be backing up %APPDATA%\cura\4.8 as you indicated.
@ahoeben OK. Thank you!
You can also enable the backup plugin. It's shipped with Cura by default.
2 hours ago, nallath said:You can also enable the backup plugin. It's shipped with Cura by default.
@nallath Yes. It's a cloud-based functionaility. Thank you!
Mari 35
