I had the exact same problem. Originally started up with Cura 4.4, which included the Tenlog. When it offered to update to 4.8, I did. Suddenly Tenlog was gone, but it came up with a message saying certain profiles were missing and offered to add them. It had to re-install the whole thing for some reason, but it worked. Only thing is that Tenlog isn't listed alphabetically, it's near the top of the list instead (god knows why).
I also found Tenlog's page for adding them to Cura (while looking into a different problem):
https://www.tenlog3d.com/cura-for-tenlog-dmp-3d-printer-push-now-just-download-and-use-no-tedious-settings_n23
Hope that helps.
ahoeben 1,955
Printer definitions are not normally removed from Cura. Given that there does not seem to be any reference to tenlog printers in the current source of Cura, I'm going out on a limb and say that they were never listed in Ultimaker Cura.
Ultimaker only maintains the profiles for Ultimaker printers. For all other printers, they rely on community members or printer manufacturers to create and submit these profiles so they can be included with Cura. But some printer manufacturers choose instead to give instructions on how to add sets of files to a Cura installation. It seems that that has happened in the case of tenlog. Where did you get the screenshot of Cura 4.4? It would be my guess that the original page it was on had instructions on how to add the profiles for tenlog printers to Cura.
