GregValiant 255
An alternative to ahoeben's suggestion is to try the "rotate" tool option to "lay flat". Sometimes the model comes in at a slight angle (but Lay Flat doesn't always work if the problem is in the model).
The top and bottom patterns can be changed. "Concentric" might work well on that. If you use "Lines" you can change the angle in the setting "Top/Bottom Line Directions" by entering something like "[0,90]". The default is 45° and 135° ([45,135]) which is indicated by empty square brackets. If I have to rotate a model on the build plate to get it to fit, I often change the line directions and the infill direction.
ahoeben 1,188
The model only contacts the buildplate with a small circle. You may want to "push" it into the buildplate a little using the move tool. Set the z to -0.1
