1. I can see that so perhaps have a separate option for "Full Reset" or "Quick Tweak" or something. I find I have to tweak my build plate level every couple of weeks though.
2. Fab
3. I like that idea too.
4. This one is born out of the very frequent nozzle blockages I find I get which I usually clear by setting the temp to 260C and then manually moving through the material.
5. I can see your argument.
6. If that would be an easier solution to implement than my suggestion then I don't mind that one. I'd go as far as requesting that the motors be switched off whenever the printer isn't actually printing. This seems like a low tech but effective solution to multiple needs.
IRobertI 502
1. I'm sure this is just for safety to make sure that the build plate doesn't smack into the head. I don't find it to be that much of an issue, I just raise the bed to be very very close in the very first step and then quickly skip the next two position before finally getting to the fine tuning step. The best part is that the bed seems super stable and I've only levelled a few times when tweaking.
2. Daid is aware and will have this fixed in the next release.
3. Yes please
Also, maybe some sort of "acceleration"? Like if you spin quickly the temp goes up in increments of 10.
4. Personally I'm indifferent to this one. Maybe make it possible to adjust the temperature in that dialog as well somehow?
5. I think this would be hard to do since you can set different speeds for different parts of the print, there isn't one single global speed that is being used. Like the first layers, they slowly ramp up in speed layer by layer. If you set a speed of "50mm/s", where should it then be applied?
6. I would love a "turn off motors" option. Both to be able to move things around easily but also to kill that annoying sound that steppers make when they're in hold position. Like you say you can switch the printer on and off but that feels so brute forcy
