Hi gr5,
I am doing my bachelors and i needed sometihng to work on, so I came up with this 🙂
Edited by denix5655
1
Hi gr5,
Edited by denix5655
Today I was thinking of doing something similar - I have some nest thermostats and I learned there is an API so I could make a web page that lets you see all the thermostats in all your homes all on the same screen and adjust them all from one screen and then I could have an ipad on the wall permanently...
Just a thought.
On 3/15/2023 at 5:28 PM, gr5 said:Today I was thinking of doing something similar - I have some nest thermostats and I learned there is an API so I could make a web page that lets you see all the thermostats in all your homes all on the same screen and adjust them all from one screen and then I could have an ipad on the wall permanently...
Just a thought.
That is a good idea 😄
If the API is similar to what Ultimaker has to offer then it should be relatively easy 😄
What languages do you code in?
denix5655 2
I am working on making a website where users upload theri gcode and then print from an avalible ultimker 3, with this code i managed to get the printer to work:
var url = "http://YOUR IP/api/v1/print_job";
var apiKey = "YOUR API KEY";
var apiSecret = "YOUR API SECRET";
var jobName = fileResponse.FileName;
var filePath = fileResponse.FullFilePath; //full file path to the file
using var handler = new HttpClientHandler
Credentials = new NetworkCredential(apiKey, apiSecret)
using var client = new HttpClient(handler);
using var fileStream = new FileStream(filePath, FileMode.Open);
using var content = new MultipartFormDataContent();
using var fileContent = new StreamContent(fileStream);
fileContent.Headers.ContentType = MediaTypeHeaderValue.Parse("application/octet-stream");
content.Add(fileContent, "file", jobName);
var response = await client.PostAsync(url, content);
if (response.IsSuccessStatusCode)
var responseContent = await response.Content.ReadAsStringAsync();
Console.WriteLine(responseContent);
I know that the post is old but I hope if anyone ever tries this again then it can come in handy.
gr5 2,070
Thanks for helping others. Why don't you want to use digital factory?
