Just to add to Ian's post, the side fans don't come on at the very start of the print if you're using cura's defaults. They will come on gradually during the first few layers. You can however test them manually if you go into the tuning menu after you have started the print.
Also, check to make sure that the little pins inside the fan connectors are secure. On one of mine the pin was loose and I had to re-secure it in place by bending out the little "hook" that locks it in place before stuffing it back into the connector.
ian 32
the back fan is meant to be always on.. and when printing the two fans.. left and right should also be on.
Check your cable connections going to the base of the left fan.. also if this looks all ok... you can carefully remove the shield around the electronics and check the connection there also... check also that the cable wire going the left fan has not been pinched or cut behind the print head..
Keep us updated.
Ian :-)
