1 hour ago, geert_2 said:Annealing does not just shrink the model by 5%: it shrinks it in X- and Y-size, but it gets thicker in Z-size, and it severely warps due to the relaxation of built-in stresses. Better use filament that can handle the required temperatures from the beginning. And even then, the result is only a poor less than 10°C better temp-resistance for PLA: still not usable in a car, it will still deform in a mild spring sun.
I tried annealing in different ways: by putting a fridge box on top of the model, and keep the build-plate hot (60...70°C for PLA). And in my well-controlled lab-oven.
An untreated, and a "too well" treated model (a bit too high temp): this one got much shorter, but much thicker. And it obviously warped severely...
Some filaments warp in both directions: first upwards, then after a day in the opposite direction downwards. Very weird, I have no explanation for this, and very unpredictable. Thus unusable for accurate parts.
Thanks for those test results 😂, it’s a sad story, but the results are funny... I did not start my test yet, so I don’t know it has that much trouble... but not surprised about these happened. Failed to search any information out from google... well my trouble happens again, way too many ideas... like to build a abs case( I did tried nylon with pla, don’t stick together makes it easier to take apart, don’t know about abs but probably can be washed away ) to try to eliminate the shape changing, and the second idea is to add a reheater on the nozzle, to reheat the lower side of the part for annealing while printing, don’t know if any more ideas will come out soon... and it only interrupts me cause I have other stuff not finished to do... too many ideas don’t help much.
nallath 879
UUh. The electronics inside of the printer can't stand that high temperatures. For the anealing you will need the entire volume to reach temperatures of 120 degrees. The slider blocks are made of ABS, which will melt well below that temperature.
I'd strongly recommend that you first get the annealing process working outside of the printer before you even think about trying to combine the two.
geert_2 485
