X/Y axis not calibrated?
Posted (edited) · X/Y axis not calibrated?
I have printed this pentagon frame on my Ender-3 Pro.
There is distortion that does not seem to be simple X or Y miscalibration.
In the picture, you can see that the outer parts of the frame have varying widths, same goes for the inner diagonals.
The vertical direction is the X axis.
Problems I have already found solutions for:
The "wobbles" in the rightmost part of the frame, I have learned, are due to flat spots on the Y wheels.
The 2 holes in the drawing not appearing in the print are due to being surrounded by an unbroken surface in the model. I forgot about that during the modeling phase. My first iteration (not shown) included completely unbroken top and bottom surfaces, which would have resulted in a solid pentagon shape.
CE3PRO_pentagon2.gcode
Edited by Splatman
    • 2 weeks later...
    Posted · X/Y axis not calibrated?
    Found out what was probably the problem: The wheels were too tight. I adjusted their tightness to deal with the 'wiggles', and that seems to have solved the other problem. Now off to deal with a new problem: Each layer shifted by a bit less than their height, causing the entire print to be skewed front-to-back.
    The skewing turned out to be a loose screw on said wheel, that got increasingly loose, allowing the hotend to sag, producing the skewed effect. I tightened said screw, and ran a successful print.
    There's the skewed result:
    The white layer on the bottom is leftover sample PLA that came with my Ender-3. It's the same PLA I used for the (unsuccessful) print in the first post.
    Here's the successful one:
    I got creative with the 2 colors of PLA that I have. Lime Green and Purple from Matterhackers.
