Setting second extruder as a backup - is it possible?
MarjorieFinnigan
Posted · Setting second extruder as a backup - is it possible?
Not in dynamique mode. But we can imagine a post processing script where you define the quantity of material remaining on the spool ( current spool weight ) and when this theoritical quantity is reached switch to the second extruder.
Just an idea not a solution
