hmm, didn't get a notification email. Odd. Anyway, mine is a cr-10 max so only 1 extruder (no MMU upgrades)
If it is being respected, then why does the sidebar flow still sais 100%, unless i manually change it to 85? Or am i misinterpreting. Which one is correct?
- i specify a flow of 85 in material settings, leave cura at 100 (default) => should result in 85% flow (desired)
- i specify a flow of 85 in material settings, leave cura at 100 (default) => results in 100% flow
- i specify a flow of 85 in material settings, leave cura at 100 (default) EXCEP¨T i change "initial layer flow to 105%" for example => results in a 105% flow for layer 1 (or the number of "slow" layers?), after that changes to the flow in material settings (in this case 85%)
- does changing quality profile override user material flow?
nallath 1,124
It is being respected; it's just that some other profile might override it. You can find more info about this here: https://github.com/Ultimaker/Cura/wiki/Profiles-&-Settings
