1 hour ago, skovatch said:Could 4.9 be turning this on in reaction to some other setting?
No, not really.
1 hour ago, skovatch said:I see the "setting has a different value than what is set in the profile" indicator.
That means that either you changed the setting value from its default. Or it could be your cat. But more likely it was you, while scrolling through the settings you may have inadvertently clicked on the checkbox.
nallath 1,125
You enabled the "Remove all holes" setting, so Cura is doing just that.
skovatch 0
Well, I definitely didn't do that on purpose -- I didn't even know that setting existed!
Could 4.9 be turning this on in reaction to some other setting? I see the "setting has a different value than what is set in the profile" indicator.
In any event, thanks for the easy fix. I'll look out for this in future projects.
